2022-03-16 12:14 PM
For the ULN2002, ULN2003, and ULN2004 the datasheet gives detailed information depending on the continuous collector current, but no such info is given for the ULN2001.
2022-03-16 1:55 PM
Welcome, @kevindarmstadt, to the community!
There is a simple reason for this: the ULN2001 is a simple multichannel bipolar Darlington transistor, whereas ULN2002...2004 each have a series resistor at the base.
The ULN2001 is therefore driven like an npn transistor, except that it has two base-emitter junctions in series, as is usual with Darlington.
You will find the differences in fig 1 on page 3 of the data sheet.
Does it answer your question?
/Peter
