2022-03-15 1:02 AM
Hi
We observe sudden changes and flickering especially at low level luminosity.
attached oscilloscope capture_1 is taken at one of green LED channels. During the dimming cycle, the ghost pattern causes momentary flashes in LED brightness.
again oscilloscope capture_2.PNG and oscilloscope capture_3.PNG are taken at one of green channels. In this case LOW side resistor of output driver value decreased; and noticed a noise at ON state. There is also a flicker in this case and we suppose the cause is the noise seen in oscilloscope capture_3.PNG.
The flickering and flashing mostly seen at low luminosity values.
Do you have and suggestion on fixing these?
our design is:
LED7708 : 10 channels active, and 8 LEDs on each channel. There are 4 LED7708s on the same board.
LED PN : osram LRTB GVTG
thanks,
Baris
2022-03-17 1:30 AM
SOLVED
C19 (parallel to Riseth resistor) marked as NC in the evaluation board schematics, was populated in our design. Removing this cap. solved the problem.
2022-03-17 1:30 AM
SOLVED
