2024-11-06 10:31 AM
Hello, I purchased this IC and would like to use it to alternately control four different inputs so that the IC’s four outputs can switch sequentially. However, I'm currently facing an issue: I’m only providing input to a single channel, e.g., Ain, but the IC outputs on all four channels simultaneously. Could you please advise on the possible causes?
2024-11-06 11:27 AM
Thank you for your trustworthy question, but it refers to the product of another manufacturer (your preferred search engine will find it), so please ask there.
Hope that helps?
Good luck!
/Peter
