2013-11-21 9:17 AM
Also with the EVAL6480H, I have 2 boards in an SPI chain.
After configuration, I can only make the first selected board work. To make the other motor work, I need to shut the power off, start over, and select the other motor first. Don't know why this happens, I want to control both motors. #eval6480h #motor-control2013-11-22 6:26 AM
Can be ignored, problem found.
