Power management
L6470 WITH UNIPOLAR MOTOR
Posted on December 16, 2013 at 09:50I use ST L6470 with unipolar motor. L6470 is biplar type dirver, so I unconnected com line of unipolar motor. motor spec is below:  MAKER: sanyo denki  type : 103H5210-0480  1.2A/1.8DEGREE/3.3OHM. because unconnec...
sojaewoo by Associate II
  • 2383 Views
L6470 reversing problem
Posted on August 28, 2013 at 20:21We are using the L6470 in a new design. We have found that when we move to a position then reverse direction we find that the new position comes up short by 2 or 3 steps. After this initail error all future moves in...
fbasso by Associate
  • 3440 Views
L6470H :What concessions motor run better? Vibration noise
Posted on November 02, 2013 at 09:31hi,guys, how to calc ''Running target current''?? stepper motor parameter:1.5A current?nameplate?this is RMS current??????? min speed:50 steps/s,max speed 2000 steps/s, ACC 1000 steps/s2, test board:EVAL6470H &&...
xiaohu by Associate
  • 931 Views
3 watt LED driver using viper22AE
Posted on December 03, 2013 at 13:32Hi please help me to design 3 watt LED driver using viper22AE. The information given in datasheet is not getting me.
h7techs by Associate
  • 1467 Views
SPI chain EVAL6480H motor
Posted on November 21, 2013 at 18:17Also with the EVAL6480H, I have 2 boards in an SPI chain. After configuration, I can only make the first selected board work. To make the other motor work, I need to shut the power off, start over, and select the ...
robert2 by Associate II
  • 969 Views
Viper53 Eval Board Schematic CAD
Posted on November 14, 2013 at 18:33Would anyone have the schematic source for the Viper53 board STEVAL-ISA013V1  ? (Any format - Orcad, PADS, Eagle, etc ...)
STM32F100RBT6B 3V3 to Drive L6208 Stepper Motor Direct
Posted on October 15, 2013 at 13:48Hy, i must build a new board for control Stepper Motor. The pwm control logic and all, is manage with new cortex STM like STM32F100RBT6B. I want an unique 3V3 logic supply for all, is possible drive and receive al...
michele by Associate
  • 765 Views
L6470 vs L6472
Posted on October 02, 2013 at 17:40Hello I understand: 6470 uses voltage mode drive/bemf compensation  6472 uses current mode drive/adaptive decay comp compensation If my uStep requirements are 1/16. What other parameters should I consider for my de...
ppostig by Associate
  • 1618 Views
[Question] BLDC motor torque and speed control with L6235 / L6229
Posted on October 20, 2013 at 01:31Hello I would like to ask to the experts a question regarding BLDC motor control. I am currently trying to develop a Brushless motor controller that allows me to control the torque and speed of the motor. The motor...
n2 by Associate
  • 931 Views
L4891A
Posted on October 13, 2013 at 13:34Hello, I am not sure if this is the right forum to post in. My question is about the L4891 PFC controller, Is there any calculator for extracting the inductor value, and all other values? Its going to be a very com...
info23 by Associate
  • 924 Views
