2003-01-31 3:29 AM
PC and Emulator connection problems
2011-05-17 1:16 AM
Hi
Sometimes the system works well. ( ST72141 ) But sometimes the Emulator : ST7 HDS2 Emulator (ST7MDT5-EMU2B) Could not link to PC: We modified the compatible Parallel Port Modes. But it doesn’t working well The error messages when started to debugging were shown as follow… Starting debug session... -> Emulator reset (LPT1)... ** Connection error (LPT1): gdi-error in hds: communication error with emulator board -> Failed to connect target. How can we solve the problem !! Help Me Please!!2011-05-17 1:16 AM
I have the same problem. It seems to be caused by a shutdown/turnon sequence between the emulator and software. I usually turn everthing off then back on and then it starts working again.
