2015-12-25 10:38 PM
I m looking for BLDC motor driver IC which can have 15amp output current. I came across L6230 driver ic, but is giving nearly 2.5amp. I need help to implement with l6230. I have doubt as follows.If i use L6230 and if i connect mosfet for the three output pins, then will it work? #l6230We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
