Power management
Documentation bug in CD00298474.pdf
Posted on December 19, 2015 at 22:32Hi, I came across a posting by someone who asked where to report documentation bugs. The answer was: post them here. But I can't find the posting anymore. My bad. But anyway: I found a bug:   CD00298474 refers to ...
Supply of the POWERSTEP01 IC
Posted on January 04, 2016 at 11:00Supply of the POWERSTEP01 IC I have recently completed a design using the POWERSTEP01 IC which I think is a great chip, however there is no stock available of this chip anywhere in the world. Some distributors are ...
graham2 by Associate
  • 781 Views
eval6470h
Posted on December 29, 2015 at 15:43Hi.What is the pcb thickness of eval6470h ?I need to know it about my design with bipolar motor stepper with 1,5A rms for phase.Can the eval work at 50°C with this current value ?Thanks.Mario.
soccini by Associate
  • 734 Views
Need help with BLDC motor driver
Posted on December 26, 2015 at 07:38Hi,I m looking for BLDC motor driver IC which can have 15amp output current. I came across L6230 driver ic, but is giving nearly 2.5amp. I need help to implement with l6230. I have doubt as follows.If i use L6230 ...
SS.Sagar by Associate III
  • 661 Views
L6470 limit switch problem
Posted on December 03, 2015 at 19:57Ive using 4 L6470 in a 3D printer application. The limit switch inputs are acting erratically. Sometime they work, when switch goes low driver stops, and I can see the switch input on the status. But then other ti...
trust by Associate
  • 736 Views
Trying to build example project for X-NUCLEO-IHM07M1
Posted on November 17, 2015 at 02:16Hello, I'm having trouble building any of the example projects in the SPN7 package.  I'm using AC6 tools on the Nucleo-030 board.  The projects can be imported but won't build due to many many wrong paths for incl...
L6482 tick period
Posted on October 23, 2015 at 01:53Many of the equations for the motion controller within the L6482 use 250 ns as their time reference (tick). Does this value scale with clock frequency or is it divided by the appropriate values to always generate a...
dandull9 by Associate
  • 1044 Views
