2022-07-14 8:16 PM
Dear Support,
Please help to share marking information for the part number L99DZ100GTR?
The marking info in the datasheet do not show the date code.
2022-07-15 12:11 AM
The date code is as usual: three characters in the middle on the right mean YWW, i.e. last digit of the year and calendar week.
This date code should also be found on the bag label.
Does it answer your question?
/Peter
2022-07-15 12:11 AM
/Peter
2022-07-15 12:38 AM
thank you and noted on this.
2022-07-15 1:09 AM
You're welcome!
If the problem is resolved, please mark this topic as answered by selecting Select as best. As you know this will help other users find that answer faster.
Thank you and regards
/Peter
2022-08-24 1:04 AM
Hi Peter,
Please confirm if the full marking of the "E3" version is correct for L99DZ100GTR.
Thanks
2022-08-24 1:07 AM
Hi Peter,
Can you provide datasheet related to e3 version's full marking? And why is there no datasheet for e3 marking on the Internet?
2022-08-25 6:34 AM
The e3 marking is in accordance with the standard IPC/JEDEC J-STD-609. It uses the JEDEC Pb-Free Category e3 logo because e3 stands for surface coating with tin (Sn).
/Peter
