2026-05-01 4:26 PM
Hello, we are having an issue where our cell voltage readings are drifting when discharging. When there is no current, the voltages all read correctly. However, during discharge, we see that cell 5 and cell 1 have lower voltage readings by about 150mV at 5A. Once discharge is ended, the voltages level off again. I have checked that this is reflected in the registers.
These are our filter settings:
2026-05-04 4:53 AM
Based on the L9961 data sheet, the behaviour is likely related to the measurement timing and input filter settling under load, rather than a pure ADC accuracy issue.
A few key points:
Recommendations:
/Peter
2026-05-04 4:53 AM
A few key points:
Recommendations:
/Peter
