2023-09-26 2:00 PM
I’m trying to find a replacement for this device from a light dimmer. I think it’s a triac, but the numbers on the front don’t match any search results, other than a similar request on this forum, so I’m hoping that someone can help!
2023-09-26 4:10 PM
T2535T-6IL. Probably can be replaced with T2535T-8I.
2023-09-26 2:21 PM
Hello @OrrinC
I think is going to be better to contact your local ST sales and marketing agent. I think he can help you.
Best regards.
II
2023-09-26 3:09 PM
I suspect it is not a consumer part, but a special order part by some manufacturer.
2023-09-26 4:10 PM
2023-09-26 6:06 PM - edited 2023-09-26 6:07 PM
Maybe this one:
https://altronika.ru/btb06-600bwrg-simistor-600v-6a-50ma-3q-bessnabbernyy/
2023-09-26 6:18 PM
BTB- is a non-insulated version! That would not work (long!). I’m going to try a BTA12-800CWRG. It looks very similar to the T2535T-8I except a lower current rating, but the dimmer is only rated at 600W, so it should be fine …. Unless I’m missing something …
