2019-12-24 4:38 AM
2019-12-24 10:49 PM
is the chip getting hot ? then it would be shutting down
did you use the correct inductor? you would need one that has a working current of 3-5Amps so it does not self heat.
does the input power supply droop ? did you check that on a scope ?
