2025-05-21 3:43 AM - last edited on 2025-06-23 1:45 AM by Andrew Neil
Hi, i made up a set up of 4 cells and I connected them to the connector of eval-l9963e-mcu. I already changed 4 cells, cause it seems like there is a dissipation for the cells. When I active the balance by GUI i don't see that the cells are balancing, oyherwise they seem like are discarge fast.
Can I know if there is someone that have used the GUI and if he as find problems like mine
Thank you so much
2025-05-28 9:26 AM
Please notice that the tool you are using is out of support.
A getting started User Manual:
Best Regards,
AutoDevKit Team
