2005-10-18 4:43 AM
2011-05-17 1:19 AM
2011-05-17 1:19 AM
the explanation at your question is not so straightforward! There is a lot of concepts related to apply PWM either on high or and low side. Fortunately for you, there is also a lot of documentation that explains everything. So, I advice you to address the following URL:http://mcu.st.com/mcu/modules.php?name=mcu&file=devicedocs&DEV=ST7MC2N6&FAM=15
and donwload the following ANs: AN1946, AN2030, AN2009, AN1905. After your reading, all should be more clear. If not, please, contact again the forum for further explanations. Best regards, TanioWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
