2005-10-10 12:46 AM
EVAL 6208, RS232, stepping motor (problem)
2011-05-17 1:19 AM
Hey,
I've a problem with my stepper motor. I'd like to control with PractiSPIN but if I push ''connect to ST7 hardware'', I received an error. I got some manuals and pdf's but I didn't find anything. Can someone help my? regards, b.scherrer2011-05-17 1:19 AM
have you checked the microcontroller receives the 5V supply voltage? If this is ok and you have the ST7 programmer, you can try programming the uC with the stepper.s19 file that comes in your C:\Program Files\PractiSPIN directory.
Regards VincenzoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
