2013-10-13 4:34 AM
I am not sure if this is the right forum to post in. My question is about the L4891 PFC controller, Is there any calculator for extracting the inductor value, and all other values? Its going to be a very complex tast to do it using the formulas. I have seen many other controllers comes with these powerful tools. And I don't know why ST don't have it. Also, Is it possible to replace the MOSFET power switch with IGBT? Regards2013-10-16 6:50 AM
In type of subject is error, controller type must be specified L4981.
I recommend using AN628 http://www.st.com/web/en/resource/technical/document/application_note/CD00003936.pdf
and AN829
http://www.st.com/web/en/resource/technical/document/application_note/CD00003943.pdf
Arithmetic is always the easiest job for the design engineer.
Good luck!
