Power management
Spice libs L4984D | STW62NM60N | STTH3006DPI
Posted on May 19, 2015 at 09:25Hi, i am not sure if this is the correct forum, but i am searching for the libraries for the following products: L4984D STW62NM60N STTH3006DPI Are there any .lib available for LTSpice or PSpice and can you please post ...
jherzog by Associate
  • 630 Views
Understanding L9942 Stepper Motor Driver
Posted on May 08, 2015 at 07:15Dear All,Thank You for your great support as always..I have the following clarifications, Tried to set STALL threshold using the AN2650 procedure, when the STALL threshold value is 00000000 STALL is not set, but when...
siva2 by Associate II
  • 1246 Views
Rogowski Coil using STPM01
Posted on April 29, 2015 at 14:06Hi, I am a student and i am trying to build a current sensing device using rogowski coil and STPM01. I am 'blind' to this project. I read on the datasheet that STPM01 can be used as a single chip monophase energy met...
endie by Associate
  • 688 Views
problem with DfuSe tool
Posted on April 25, 2015 at 11:52HiI want to use to DfuSe tool for my application. I use L6470 stepper motor driver and STM32F107RC microcontroller in my board. My DfuSe tool is V3.0.4. I load firmware to the board by using the DfuSe demonstration s...
yasamin by Associate II
  • 1751 Views
L6480H driver stall detection and overcurrent detection
Posted on April 16, 2015 at 16:16In application note AN4355, overcurrent detection page 18 and stall detection page 21, application note writes two equationsEquation 1: IOCDth = VOCDth � Rds(ON)Equation 2: ISTALLth = VSTALLth � Rds(ON)Why current is...
cliang by Associate II
  • 869 Views
VNH3SP30-E overheating issue
Posted on April 22, 2015 at 18:22Hello all, I am having a bit of trouble with the VNH3SP30-E overheating. the part should be capable of supplying 30Amps continuously however when I supply 20 amps the chip overheats and shuts down after around 10 sec...
liam by Associate
  • 661 Views
L9942 Driver IC SPI Programming
Posted on April 01, 2015 at 12:58Dear Experts,I am new to L9942 Driver IC.I am currently working on this IC for a stepper motor control in automotive safety application.I have attached a 'c' program written for SPI communication with L9942. The cont...
  • 4172 Views
bugs and crash of V 2.2 SPINfamily GUI
Posted on April 09, 2015 at 21:02The new version (V2.2 stsw-spin002.zip)  has a much improved setting of motor paramaters, and it now works on XP but the GUI still crashes badly so motors cannot be tested. # GUI crashes hard in both XP and Win 7, in...
scope by Associate II
  • 533 Views
