Power management
How long will STTH810D diode last at Tj = 126degC?
We are using the STTH810D in our new 60W offline  Flyback LED driver. It is dissipating 4W. We measured its metal tab as operating at 115degC. Therefore its junction is operating at 126degC.This product is supposed to operate for 8 hours per night , ...
amass.9 by Associate II
  • 680 Views
L6480 best driving (from motor motion perspective) strategy question
Hi all,I'm developing a bipolar stepper motor application by means of a STEVAL-PCC009V2 + EVAL6480H boards coupled together.My application have to follow a position by means of an incremental encoder that is connected to the encoder quadrature module...
FF1 by Associate III
  • 808 Views
EVAL6480H-DISC
Posted on December 18, 2014 at 17:57Hi,does anyone know when the EVAL6480H-DISC will be available in the UK? Also will it be cheaper than the EVAL6480H evaluation board?Thanks in advance,Howard Smith #eval6480h #eval6480h-disc #l6480
howard2 by Associate
  • 1015 Views
L6591 issue
Hi at everyone,I designed a open loop dc/ac converter, but I met a big problem. The high side output did'nt work correctly over the 40V of Vhv. Over that value the output goes out derivates and the resistance from pin 14 and pin 13 is 5ohm. Aflter a ...
VSimo.18 by Associate II
  • 734 Views
STPM32 Power meter with load relays on both mains lines
Hi, I'm trying to build a power meter that has the ability to switch on and off the attached load.The power supply for the design is created using Viper26LD in buck mode, the processor used to control the design is STM32L051. The entire design analog...
Converts DC-DC PV in series
Hi, I have questions about how serial DC-DC converters work for photovoltaic systems. For, the current in the output tends to be different due to MPPT, which would be several sources of current in series. I read the manual that explains the SPV1020, ...
