Power management
STC3100 VCC to GND short
Hi, I designed battery powered circuit using STC3100 as battery monitoring. I started soldering the prototype and it appears that there is a short between VCC Pin and GND. (Short seen with a multimeter, I did not connect the battery, so I dont expect...
adami by Associate
  • 1533 Views
Information and waveform plots missing for L9758 datasheet
Hi,Can we have some more data for L9758? Datasheet provides very less information. Typical application schematic (external components values/part numbers)Typical performance characteristicsStart-up, efficiency, shutdown, load and line transients wave...
FCuti by Associate
  • 665 Views
Information and waveforms plot missing in L9945 Datasheet
Hi,Can we have some more data for L9945? Datasheet provides very less information. Some timing waveforms for all 8 channels(or may be only one channel, which can be replicated for the other 7 channels). Functional block diagramTypical application sch...
FCuti by Associate
  • 702 Views
Chip markings on the STSPIN32F0A
I recently purchased these from element14: https://in.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=91&urlRequestType=Base&partNumber=2797963&storeId=10186.The ones I got show this as the chip marking: https://i.imgur....
Resistor guidelines for LDL212 adjustable
Have specified LDL212 adjustable regulator in new device. Very limited information in the datasheet for selecting the R1 and R2 values. Assistance appreciated. Target VOUT is 3.6VThanks in advance
DFloh.17 by Associate
  • 872 Views
Currently I am using "STEVAL-SPIN3202" with "STSW-SPIN3202" to drive a 12V/30W, 16-pole BLDC motor by sensorless control.
However, when I pressed the button USER1 on "STEVAL-SPIN3202", the rotor spun for couple turns and then stalled. I did it several times, but got the same results. I have checked p.50 of UM2310, but haven't got the motor running. What are possibilitoe...
MChen.19 by Associate
  • 579 Views
