Power management
Why am I killing NFET on low side of motor drive?
I am using an STS10N3LH5 on the low side of a half bridge circuit. I have a schottky diode across the motor. For lighting applications we PWM the ground and everything is fine. However, during motor applications we PWM the high side and will somet...
Li-ion battery charger.
I want to design a Li-ion battery charger.Q1. How charge will know that it should work in constant current or constant voltage mode?Q2. How same charger can be configured for constant voltage and constant current operation?Regards,Vivek
VAgar.1 by Associate
  • 834 Views
BTA16-600BW not turning off
HiI have been testing the following circuit (which apparently works). I am finding that the TRIAC (BTA16-600BW) does not turn off with an inductive load (induction motor at 240V, 3A. 50Hz) yet with a simple house lamp the circuit works switching the ...
Andre1 by Associate II
  • 2448 Views
STSW-SPIN3202 Mini USB (ST-Link) not detected in my computer.
I recently faced an issue regarding my evaluation board STSW-SPIN3202. I was uploading the firmware to my board but unable to upload due to update issues. So, I have connected the ST-Link V2 to the board and connected it with the utility software pro...
GSrik.1 by Associate
  • 689 Views
Where do I find more detailed information on the STWBC Qi GUI used with the STEVAL-ISB044V1 Wireless Power Ref Design? How to interpret FOD metrics.
Hello, I recently started using the STEVAL-ISB044V1 Wireless Power Ref Design and it looks really useful. I am trying to figure out how to interpret some of the data in the FOD Metrics GUI. For example, if it click on the "Snapshot FOD internal metri...
MSamp.1 by Associate
  • 675 Views
What am I doing wrong with the l6470 stepper driver?
We develop electronics for controlling multiple stepper motors and use the L6470 as drivers. Radiators with fan cooling mounted on the chip of the driver (above). The current does not exceed 2 amperes. Radiators remain cold.The problem is that driver...
kirlik by Associate II
  • 1718 Views
How to read the Datecode
Hello Everybody,please could you help me with one part (STP16CP05TTR).I would like to know how to read the Datecode/Tracecode at the part.STM shows everytime the tracecode on the label and also at parts.And i know that datecode is within the traceco...
PKohl by Associate
  • 1725 Views
