Resolved! Any Spice / LTspice model for the STSPIN233 ?
I'm modeling the pwm performance and would like to find a spice model for the driver stage --- thanks...
Hello!I need to measure AC and DC voltage, current and power using the same input depending on what type of voltage source the end user decides to connect to that channel. The same question asked Tom MacDonald here (https://community.st.com/s/questio...
Can anyone explain me, how internally COMP pin voltage of IC is regulated by changing current sunk from pin.Thanks
Hi,I'm using STWBC-EP and connected it to my host micro controller through UART. I'd like to retrieve different register values over UART while my device is getting charged over the charger. One of them registers that I'm interested in is HOST_IF_STA...
We are a factory for new energy vehicles. I would like to find a CCC or CQC or CE certificate for this model. Could you please provide us with it? Thank you!
Hello,I am interested in L6258EA motor driver for our new project. L6258EA will be interfaced to micro controller for controlling our electric expansion valve (stepped motor based). I could not find detailed evaluation circuit in ST website. I c...
Building a very big LED array and need to get the frequency of the LED6000 up to about 1MHZ. But working with eDesign I find that a bandwidth error comes up a lot. When I hover over it to more information it show something about TON. Trying to nar...
I am developing the firmware to control the L6470 IC.On my board the L6470 uses an internal clock.The main factor in motor control is tick.There is no information on tick setting in the L6470 data sheet, all calculations are based on 250ns.When using...
