Resolved! STSPIN32F0 PF6 PF7 找�?到管脚
https://www.st.com/en/evaluation-tools/eval-l9958.html
https://my.st.com/resource/en/data_brief/p-nucleo-ihm001.pdf 403 Forbidden: You don't have permission to access /resource/en/data_brief/p-nucleo-ihm001.pdf on this server.https://my.st.com/content/my_st_com/en/products/evaluation-tools/product-evalua...
Should the 220nF bootstrap capacitor connected to ground or Vs? The circuit diagramm and the datasheet are describing it differently. Both can be found here: https://www.st.com/en/motor-drivers/l6234.htmlThank you.
ESD Diode protect
Need more information for the current consumed by this ic as i have to design the smps circuit depending on the load of STGIB30M60TS-L
Hello. I am using 70 Ohm load to test STEVAL-POE005V1 board.Without load board indicate T1,T2,T3 leds and D2 blue led is on. 54V out. When i connected load - everything works well.But when i try to connect load before powering board throught ethernet...
Where is pin on STEVAL-SPIN3201 for connected other signals - from gyro or control signals? (Can I use UART? )
