Power management
PM8803C asserts TP2 without 802.3at Type 2 sequence
I have a PM8803C which asserts the TP2 pin when it only sees a single classification event (vs 2 event for Type 2 per 802.3at standard). I believe a non-standard 2.3ms 6v pulses for 114ms delivered on power up triggers the PM8803C to assert TP2.Can a...
AChas.2 by Associate
  • 835 Views
Resolved! HI, I'm testing STEVAL-ISA178V1 evaluation board. When I connect the DC output to the oscilloscope, it gets short circuited.
The fuse of the AC mains gets switched off. I tried to connect the oscilloscope through a 10k resistor and the same behavior was observed. However, I could verify that the switching regulator works fine by measuring the voltage with a voltmeter. Both...
TAswi.1 by Associate
  • 1991 Views
