Power management
Resolved! Subject is MOC3021 : What is the typical control voltage ?
Il the decription of the datasheet we can read this text :They are designed for interfacing between electronic controls and power triacs to control resistive and inductive loads for 115 VAC operationsBut in the Typical Application Circuit (figure 12)...
MHéna.1 by Associate III
  • 2263 Views
L7981 Random Dropouts
Hi, I'm looking for technical help on an L7981 voltage regulator issue. We have been using these for years in various designs with minimal issue. On a recent new prototype, I am having an issue I have never seen before, where on occasion the regulato...
MGarr by Associate
  • 2856 Views
How can I reduce L6472 Stepper Motor Noise due to harmonics?
I have a motor control PCB with x6 L6472PD stepper motor drivers on. 2 of the drivers are being used to drive NEMA17 "hybrid stepper" linear actuators that move a module along a linear guide. The two drive systems are laid out identically, and conven...
LWalk.1 by Associate II
  • 2501 Views
Measuring the frequency response of an optocoupler (e.g. PC817C) with different pull-up resistors using a Bode 100.
My test reference circuit is from Mr. Christophe Basso's book: "Designing Control Loops for Linear and Switching Power Supplies By A Tutorial Guide"The picture is showed as follow.Unfortunately, it may be a problem with my test circuit, or maybe the ...
SRC0GS22D POWER RESET
I am trying to reset the power by controlling GPIO3.3V.However, the initial power is ON and OFF only, and there is no control thereafter.
KSUWA.11 by Associate
  • 921 Views
PM8800 PoE Issues (high ripples)
We designed board with PoE capability using ST PM8800 chip. We encountered some problems.Issue #1When our board is powered from external power supply (Vin(AUXII)=32V) we get output voltage with high ripples and PM8800 nPGD is inactive (High). Ripple ...
DRusi by Associate
  • 2060 Views
