Hello forum! I purchased the STEVAL-ISA147V3 for evaluation. I am glad to report it powers on and drives a load. However, the code is not up on the product page. Can you please send it?There is an older question on the forum about this, but no reply ...
My colleague already has the kit so I'm only interested in monitoring and the simplest tweak. A whole dev kit would be a waste.
Hi,is there a Arduino Library for the STPM32 Measurment IC?
Description:This is what we did with the EVAL6235Q to use the external speed loop connector to drive a BLDC motor:1. On the power supply connector, we attached 12 V.2. We connected our BLDC motor to the 3ph BLDC motor connector.3. We ...
is it possible to have email address for technical support??
Hi, I was wondering if you could attach the exposed center pad of the L6234 IC to GND to get better heat dissipation throughout the PCB?The datasheet does not mention anything about the exposed center pad.Thanks!Best regards Niklas Cooke
