Resolved! Direct replacements for STBC15
Now that STBC15 is marked as NRND, is there any direct or close substitute that is planned?
Hi everyone,I am searching for LT spice model of SMA6T28CAY diode. can someone please help me to find this and integrate in LTspice application. Best Regards Vedanth.
Regarding the STPS5H100AF, the datasheet states that the storage temperature is -65 to 175°C, but there is no mention of the operating temperature.What is the operating temperature?
Hi,Our development board uses BQ25120A for battery management.In the datasheet section 10.2.2.1 Default Settings, there is a statement:• If the function is not needed, connect TS to the center tab of the resistor divider between VIN and the ground.(p...
In our application we use the STPM801 as a switch and fuse. The fuse characteristic is, by default, very linear (except some filter/blanking times). Is it possible to give the fuse a I2t characteristic like old fashioned fuses/thermal fuses?I did exp...
Hi,I can't find any information about this diode. What is the actual name of this diode on ST?DEGP025
How to drive HSD and LSD pin using SPI command in EVAL BOARD L9301 and we need technical details what frame we have to send form our ECU to actuate the LSD and HSD drive and even more technical details related to this we are waiting for your immediat...
hi everyone, can anyone steer me to a Datasheet for this, or an identification please? thanks, elts
Hello,We see that there are Qi2.2 25W transmitters that have been certified. Is there any roadmap for Qi2.2 25W receivers?Thanks
Hi, Does Spice Model of VIPERGAN65D available? If so from where can I download it?
