Power management
POWERSTEP01 external step input
When using the external step input of the Powerstep01, will the internal logic also use the advanced fast decay mode and switch between micro and fullsteps if a given speed limit is reached?Or does the step input only count microsteps and not using a...
pf8645 by Associate II
  • 1192 Views
What is max speed of POWERSTEP01 in steps/sec?
In the STPSIN software, it seems that I am limited to 15609.741 Steps / sec?(See picture below)With a 0.9 degree motor (400 steps / revolution)this limits me to15609 steps/sec * 1 rev/400 steps * 60 sec/1 minute = 2341 RPMIs this the maximum speed o...
CBeif.1 by Associate II
  • 2911 Views
Mastergan technical questions
Hello all,1) what is the recoverytime of the internal bootstrap diode from the mastergan4L2) why this diode need a parallel one for the frequencies above 500 KHzThanks for answeringGentleRV
GentleRV by Associate
  • 696 Views
IPS1025H/IPS2050h datasheet update.
Hello,i'm using some ips2050h-32 and ips1025h-32 from last year. Checking the datasheets, on the revision history they result been modified on july 2023, on table1, FLTx pins. Compared to the old version, seems that now it's been added the disclaimer...
lgenn1 by Associate
  • 1398 Views
