2025-08-21 9:37 PM
I would like to use the ACST series as an AC switch for a 90kHz AC capacitive load. Is this possible?
2025-08-22 12:49 AM
No, TRIACs are designed for mains frequency and cannot be used at such high frequencies. In addition, you want to switch a capacitive load, which results in large peak currents.
You might be able to solve your problem with fast IGBTs:
Hope that helps?
/Peter
2025-08-22 12:49 AM
Hope that helps?
/Peter
