2019-09-05 7:48 AM
I absolutely do not understand under what conditions and for what reason sometimes during operation of the LLC converter, the power transformer emits audible high-frequency acoustic noise. Some instances work fine, but some make a good audible noise. What is the reason for this noise and how to avoid it?
2019-09-10 2:05 AM
Normally As per my knowledge If there is a air gap between windings or between turns, transformers tend to make hum sound.
2019-09-10 3:13 AM
Resonance of mechanical components with spectral components of the converter's frequency.
Most susceptible components are coils, with magnetic energy transfer and larger dimensions capable of mechanical oscillations.
Ever experienced clamp-mounted water pipes hum at certain pressure/flow rate ?
Usually some filling compound (epoxy, PU filler) would stop it.
