2025-06-03 10:58 PM
Hello, I am using w5500 wiznet ethernet module with my stm32H723ZGT6 mcu but it is not working. I used this same code with my F4 series controller and it is working fine but this same code after implementing it with H7 series it is not working can anyone help me out. Please refer to the attached code for reference.
2025-06-04 12:20 AM
@Aries16 wrote:I am using w5500 wiznet ethernet module
So this: https://wiznet.io/products/iethernet-chips/w5500 ?
@Aries16 wrote:with my stm32H723ZGT6 mcu .
You realise that MCU has ethernet built in?
@Aries16 wrote:it is not working.
You need to give more detail!
What testing/investigation/debugging have you done to find what's going wrong?
How to write your question to maximize your chances to find a solution.
@Aries16 wrote:I used this same code with my F4 series controller and it is working fine .
So compare & contrast your working F4 system with your non-working H7
Instrument both systems to see what's going on...
2025-06-04 12:27 AM
While Pinging from cmd prompt from my laptop and also not receiving any data on TCP server
2025-06-04 12:29 AM
So you need to dig deeper to find why it is not responding to pings or receiving TCP data.
Again, compare & contrast your working F4 system with your non-working H7 ...
