2026-01-08 1:47 AM - last edited on 2026-01-08 7:15 AM by mƎALLEm
Good morning,
I need to send data using UART to a board with a specific delay between single elements, which I obtain as I'm using LABVIEW, but on the board said specific delay is not obtained, and worst of all the delay between datas is not constant. I figured there would have been some additional delay, but is there a way to decrease it or at least make it constant? or is it intrinsic to the UART technology?
Thx all
2026-01-08 2:10 AM - edited 2026-01-08 2:21 AM
Some more detail would help:
How to write your question to maximize your chances to find a solution
@Jack_DB wrote:a specific delay between single elements
What delay, specifically?
How do you implement that delay?
What do you mean by "elements" here?
@Jack_DB wrote:I'm using LABVIEW,
LabVIEW is an independent 3rd-party product from NI - nothing to do with ST.
You need to go to NI for support with their product:
https://www.ni.com/en/support.html
@Jack_DB wrote:on the board
What board?
@Jack_DB wrote:is it intrinsic to the UART technology?
No - it must be something in your setup.
As we know nothing about your setup, hard to guess what it might be.
Try simple something like:
HAL_UART_Transmit( ... );
HAL_Delay ( ... );
PS:
@Jack_DB wrote:the delay between datas is not constant.
How do you measure this?
What delay values do you see?
#LabViewSupport
What board?
HAL_Delay ( ... );
PS:
#LabViewSupport
2026-01-08 3:13 AM
turned out to be a labview problem...
thx anyway
