2025-09-23 4:57 AM - last edited on 2025-09-25 8:48 AM by mƎALLEm
Hi Team
How can I implement the ADAS1000 ECG sensor with an STM32 board to acquire ECG waveforms using 3 leads, and how do I read the data from the sensor leads?
2025-09-26 6:48 AM
Hello @Kumar123;
I recommend you to look at this post "How can I interface the STM32F769-DISCO board with an ECG module's library to display data?" may help you.
Thank you.
Kaouthar
2025-09-26 6:55 AM - edited 2025-09-26 6:57 AM
@Kumar123 wrote:How can I implement the ADAS1000 ECG sensor with an STM32
Exactly the same way that you'd do it with any other microcontroller !
The ADAS1000 neither knows nor cares what microcontroller you use - all it sees are the signals at its IO pins.
So what you need to do is to make sure that you send all the right things to those pins - in the right order, and at the right time.
And how do you know what those things & timings are? They will all be defined in the ADAS1000 datasheet:
https://www.analog.com/en/products/adas1000.html
How To Interface Anything To Anything Else
