2019-05-04 7:26 AM
uc : STM32446
EEPROM : M95128-W
Interface : SPI
We are sending signal 0x06 (Write Enable) oxo5 (RDSR) and getting response from EEPROM (SPI Slave)0xFF instead of 0x2.
Any Data send via SPI we are receiving 0xFF.
How to send and receive data to EEPROM With correct sequence?
How to know Slave sending data or Slave not active?
What is the possible reason to get 0xFF every sending of one byte.
Tried using different phase and polarity of signal and even put delay after sending one command.
2019-05-16 2:18 AM
Select & deselect the eeprom between each instructions ( Select ==> 0x06==> Deselect==> Select ==> 0x05 0x00 ==> Deselect)
A deselect stops any transmission if salve active.
Eeprom not selected
please follow AC/DC characteristics ( max 20MHz and vcc range according to datasheet)
https://www.st.com/resource/en/datasheet/m95128-r.pdf
BR
EEPROM suPPort Team
