2025-11-03 9:05 AM
2025-11-03 9:23 AM
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
@Dima587 wrote:I'm attempting to get started with the Morse Micro MM8018-EKH05
Did you mean MM8108-EKH05-01 ?
It's not an ST board, so Morse Micro should be your first point of call for support with their product:
https://www.morsemicro.com/dashboard/
https://community.morsemicro.com/
Your screenshots are a bit small to read!
If you just want to program the board and let it run - not debug - try STM32CubeProgrammer.
To debug, use a Debug configuration rather than 'Run'.
Are you sure that the ST-Link is properly seen by your PC?
Here are ST's tips for debugger problems:
How to solve connection errors when connecting and programming the STM32 target board.
How to solve debugger connection issues;
