2003-11-24 1:56 AM
2003-11-14 12:48 AM
Dear all,
The PWM generator of the ST7LITE09 seems to have some problems at hight frequencies (e.g. period: 30usec). Infact by changing the duty cycle close to the ends of the period, the signal is completely wrong!!(FYI I'm using an external clock 16MHz and autoreload timer). Thanks for your help.2003-11-24 1:56 AM
There is a caution given in the lite0 datsheet-
Caution: At each OVF event, the DCRx value is written in a shadow register, even if the DCR0L value has not yet been written (in this case, the shadow register will contain the new DCR0H value and the old DCR0L value). So, if you are not able to write DCR0L before OVF event, you will be getting the wrong frequency.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
