2003-11-24 12:40 AM
2003-11-22 7:24 PM
I'm working with the ST7LITE1. My application is very cost sensitive, battery powered, so i try to reduce the quentity of the external components. Is it ''safe'' to use only internal reset circuit? Should i add an external RC reset circuit? In all of my prev designed i used an external RC, but i'll be happy if i could remove it... I'll be hapy to hear from your experiance... Thanks Itamar2003-11-24 12:40 AM
Yes, you can use the internal reset circuit but you will have to use an external capacitor 0.01 uf between reset and GND. The new revision of the datasheet will have this info.
[ This message was edited by: Jatin on 24-11-2003 14:11 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
