2005-10-02 11:39 PM
What is the maximum frequency generated with timers ?
2005-10-02 10:21 PM
I'll be pleased, if it is possible to use the timer to provide a 12Mhz clock. Is it possible? What is the maximum frequency? How to? Is there another mean to get a 12MHz clock? Thanks, Ludo2005-10-02 11:39 PM
I dont think you could get 12Mhz from a timer. I could be wrong.
Probably your best bet (Assuming a 48Mhz MCLK) is to use the CKOUT pin. But this means running the APB2 peripherals at 12Mhz also.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
