2005-04-07 7:49 PM
2005-04-05 11:52 PM
Hi all,
Can you help me figure out the problem below? ''scat.scf'', line 19: Warning: L6314W: scat.scf(line 19, col 13) No section matches pattern *(RW). Finished: 0 information, 1 warning and 0 error messages. i've copied the required files from templates, lib_Linked folder and also the main.c from the examples folder. Pls advice. Im trying to run this progrm on the STR710-EVAL.2005-04-06 12:27 AM
You can ignore this warning, it is just informing you you have unused sections and it is removing them form the link stage.
Regards sjo2005-04-07 7:49 PM
thanks for d fast reply.
