2005-11-30 5:47 AM
2011-05-17 3:09 AM
I am still having trouble with creating a IAP routine. It would be much easier to troubleshoot if I only knew the structure of the WSI upload obj. I know this is a hex file but have yet to decode it.
Can anyone tell me how the hex file is layed out when uploading the flash memory?2011-05-17 3:09 AM
Open your uploaded file with the ''Conventional Programmers'' option under PSDsoft Express. There are a couple of icons that allow you to select the region that you want to display (main/secondary flash or user code). From here you will be able to see how the uploaded file is arranged.
2011-05-17 3:09 AM
Perfect! Thanks for the reply
