UBC Option Byte does not work correctly
bcn_yang
Associate
Posted on December 10, 2010 at 19:40
1 REPLY 1
brazov22
Associate II
Posted on May 17, 2011 at 15:11
how did you set UBC? If you programmed optin bytes from your firmware (C or ASM code) then you need to apply a reset to make them effective. If you used STVP to set UBC, a reset is applied by the debugger automatically to make option bytes to be loaded. I suggest you to set all option bytes using STVP.
