2008-07-08 11:25 AM
STR912FA (IAR Eval board) - Help on Startup files
2011-05-17 12:54 AM
I am using STR912FAW44x6 eval board from IAR. The LED blinky program (RAM version)from ST library works fine. I am trying to download and run the program (ROM version) from flash. I am using the ST startup files (91x_init.s and Vectors.s) from ST Micro STR91xFA Rev 2.0 Firmware Library (RVDMK). The program control doesnt switch to /reach Main. Advice on start up sequence, vectors, sample code etc. Rgds, Rushoth.2011-05-17 12:54 AM
I'm using GreenHills MULTI V5.0.3(C compiler).
Rgds RushothWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
