2008-04-14 4:47 AM
2011-05-17 12:52 AM
Hi every body,
is it possible to connect STR912 I/Os to low voltage CMOS interface (exemple SPI), and TTL interface (exemple UART),please advise :)2011-05-17 12:52 AM
As you know the VDDQ voltage range in STR9 is from 2.7 to 3.6V Referring to STR9 datasheet: -VIH= 2.0v -VIL= 0.8v -VOH = VDDQ – 0.7 -VOL = 0.4v To be TTL Compliant : you must have VDDQ – 0.7 >= 2.4V So VDDQ >=3.1v Kind regards, Eris.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
