2007-05-09 11:31 PM
2007-05-08 7:05 PM
Hello!
We made our own proto bord on the shenmatic example of ST AN1775. We used HITEX Tantino 7-9 JTAG and IDE enviroment. At the first everithing was communicating ok but at one time after 3 days of SW developtment on protobord the communication with JTAG was lost and can't be established any more. The same problem was on HITEX prototype board. We solved the problem with BOOT pins but I want to know what is the cause of that problem and how to fix it. The problem was described on KEIL internet page too. Thank you!2007-05-09 3:52 AM
Hello
We made our own proto bord too and we have problems with JTAG communication, so can you explain what you did with BOOT pins to solve your problem ? And can you give the link of the KEIL internet page where the problem is described ? Thanks in advance2007-05-09 11:31 PM
