2025-10-28 4:38 AM
I am trying to understand some features of STHV200 Dual channel ±100 V, high voltage 3 A linear amplifier and 2 A pulser transmitter.
I could not find a detailed datasheet of the product. Only data brief.
I want to use it to amplify the received low voltage signal. The data brief mentions an internal amplifier but I could not understand how it works. Am I able to amplify the received signal coming from the T/R switch? Or is the internal OP-AMP configurable for example as a differential amplifier?
2025-10-28 4:52 AM
As it's not on the website, it probably needs an NDA or other special qualification.
You'll probably need to talk to your FAE or distributor: https://www.st.com/content/st_com/en/contact-us.html
Maybe raise a support ticket: https://ols.st.com/s/
2025-10-28 4:52 AM
2025-10-28 5:06 AM
I will look into that. Thank you.
