Others: hardware and software
How to make the keyword "click" to increment every time it enters the interrupt module. Please see the code below and help me out. All the time "Click" remains 0.
#include <iostm8l.h>#include <stdio.h>#include <string.h>#include <stdlib.h>#include <stdint.h>#include <math.h>#include "defs.h"static int click = 0;void delay(unsigned long dd){  unsigned long i;  for (i=0;i<dd;i++) nop(); }void RTC(void){ unsigned...
VSrin by Associate II
  • 942 Views
stm8s001j3 pin 6 not set output mode
HiI am using STM8S001J3 controlleron my project and I'm have some problem about it,6 pin GPIOB 4 It doesn't work.I don't know how to solve it.Please help me..//example code GPIO_DeInit(GPIOB);GPIO_Init(GOIOB,GPIO_PIN_ALL,GPIO_MODE_OUT_OD_HIZ_LOW);whi...
VP by Associate II
  • 1438 Views
Programing STNRGPF01 (EVAL-IPFC01V1) how?
Hi All,I am trying to program STNRGPF01 (EVAL-IPFC01V1), but I have no success so far. I connectedFTDI serial cable to programming connector, but STNRGPF01 programming tool stays in a loopwithout any results. I also found some ld post about this, but...
STEVAL-ISB044V1 cannot communicate with ST-Link V2
I'm using theᅠSTEVAL-ISB044V1 evaluation board for the wireless charging test. The evaluation board is based on STWBC-EP and can be programmed with ST-LINK V2. STM8AF6166 is the core of it, so I post here. I tried to program the board, and there's al...
Dilemma by Associate II
  • 1116 Views
STM8 is little endian - right?
I have started writing some STM8 code in assembler and happened upon a memory assignment issue I can't explain.Globally I have segment 'ram0'Test_Word ds.w in code: ldw X, #$48 ldw Test_Word , X The two bytes of memory at location Test_Word i...
Joe.H by Senior
  • 1693 Views
Remove ROP protection on STLUX385A using ST-LINK
Hello.I have accidentally activated the ROP protection on some demo boards using STLUX385A.Normally I use ST Visual Programmer to restore the configuration bytes, but the STLUX385A is not currently supported.I own a ST-Link V2 but I can't find any fl...
SStei by Associate
  • 1505 Views
