2010-03-23 9:24 AM
startup error for 12-pole BLDC motor
2011-05-17 6:07 AM
No. As stated in the post, it is STARTUP FAILED.
I have read App note AN1276 and the issue does appears to be in the alignment ramp and startup ramp table. How can I compute the correct parameter/table values for these functions? What other parameters must I set to get the system working?
2011-05-17 6:07 AM
Is the fault condition Overcurrent?
2011-05-17 6:07 AM
I received a spreadsheet from ST online support that computes a startup ramp based on PWM freq, pole pairs, and rotational speed (rpm/s). I was able to install the new table in the code and now the motor runs fine.
