2006-08-08 10:47 PM
2006-04-27 4:43 AM
To program a ST72F561 with the ST7 Stick it takes around 3 minutes. That seems rather long for programming with a parallel port (compared to other micros).
Is there anyway to speed up the programming so that it takes less time??? The computer 1.6GHz, 2GB of RAM; nothing else is running.2006-08-08 10:47 PM
Your chip is probably driven by a slow clock.
This clock source is configured through option bytes. You can significantly improve your programming duration by ignoring current option bytes during the programming session: Select ICP OPT DISABLE in the configuration window. Then, programming the whole memory will last less than 30 seconds. Emmanuel.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
