2004-04-06 9:50 PM
2004-02-19 5:27 PM
Can any body please tell me is there any ST10 Flasher which works with WindowsXP
2004-02-22 10:24 PM
You can use ST10 Flasher v2.0 or ST10 Flasher-2.3. I am working with the two versions using Windows XP. Najoua.2004-03-11 6:55 PM
Thanks for the info.
regards, sachin2004-04-06 8:00 PM
it is great to read that it is possible to use a flasher from ST with windows xp. I am nearly getting mad with the version ST Flasher V1.6 and the version ST Flasher V2.02. Where do I get your mentioned versions 2.3 or 2.0 ? Can't find it on the web side. Or maybe there is a clue to set up XP to make it work with my versions ?2004-04-06 9:50 PM
I attach the installation pasckage of the latest ST10Flasher release, version 2.3G. It is supposed to be working under XP but depending on the installations and drivers it migth fail. ________________ Attachments : Flasherv23G.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Mi&d=%2Fa%2F0X0000000bY1%2F7WPhXmL_jutCEZdJSuY3M.pCkeCL1gegUDg3g9AKI8w&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
