2005-01-25 10:08 PM
2005-01-18 2:35 PM
hi all:
In consumeII's datasheet the sdram controll use CS0#/CAS0/RAS0 to solid sdram, but in reference sheet it use cs0/cas1/ras1. why????2005-01-25 10:08 PM
I checked in the ConsumerII's datasheet & the reference schematics we used the same for the solid sdram. You have confused with the SDRAM DIMM.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
