2010-03-05 8:29 AM
Sample firmware not working?
2011-05-17 6:07 AM
I have found the following notes regarding the beep example, did you checked it ? - Verify that the JP14 is on the up position (to enable the speaker on the STM8/128-EVAL) - Verify the speaker volume by adjusting the RV2 potentiometer position on the STM8/128-EVAL Regards, lowpowermcu2011-05-17 6:07 AM
I've been messing around with this a bit more...I think the problem was that the interrupt was not firing. I changed to the sample project where the GPIO is polled instead of interrupt driven, and it worked. Thanks for your input!We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
